Weeb
- Denver NC 28037
I'm sure the mega fangs will be more than adequate, I'm done spending money on my rear end.
Good point, but I don't think so.Nice video. Is it possible the speed difference is the result of a trim difference created by the Cobra Jet? (Bow being pushed down slightly). I know in theory less hull in the water means more speed but one of the disadvantages of these boats in my experience is the inability to change trim when you have different weights or water conditions. The 190 seems setup very bow high and the 210 is likely similar to account for possible passengers up front. Running solo the Cobra Jet fins may bring the boat to a more efficient trim angle. Just a thought.
I like the added steering control at speed with the Cobras(no fangs) with the added reverse control with the Lateral Thrusters
To me its the best combo for all around control.
I didnt feel that the steering at speed was any harder to turn without the smaller fangs
LOL. Yes, he did.@JetBoatPilot has already cracked the code on this with the lateral thrusters. Two bolts. Done.
The problem with using a setup similar to that type or the ones on a brp powered boat is you need to turn the wheel opposite direction to make the same move we currently do.I will never understand why is Yamaha not using a version of their own pump bucket with their own lateral thrusters in their boats (?).
Like those:
A simple (modified) adaptation of that would work perfectly in twins (a very simple mod).
I can not find the post/poster - someone already posted it somewhere here.
Here is the pic (that I saved):
(SORRY FOR NOT QUOTING THE AUTHOR, I WILL UPDATE WHEN I FIND THE POST!)
Obviously this would need some re-design and probably a bunch of testing to get the dimensions and angles right, but it seems like the best approach to generate lateral thrust by the pumps.
I wish I had the time to work on it... Maybe later this year, IDK. This is not a difficult mod, and the functionality is already proven - in the Yamaha's own design.
(because of the angles involved, in a twin one side would be pushing the stern, the other would be streaming into the stern- and dispersing - in reverse)
Well, it would only work in twins but no, the steering is not reversed in this concept (in the prototype bucket mod provided by the anonymous jetboater, lol, cited above).The problem with using a setup similar to that type or the ones on a brp powered boat is you need to turn the wheel opposite direction to make the same move we currently do.
My FZS reverse steering is backwards and uses that exact bucket in the first pic.
While on a ski its easy to figure out, on a boat it gets tricky
There are some caveats to the picture above of course - it is a ski bucket (not boat), so that is different, the boat pumps generate reverse through the bottom opening (red arrow):@swatski I think the flaw in the image you attached is that the reverse buckets would force water laterally any time they were in the down position. You'd have a cancelling effect if both buckets were down at the same time. The Lateral Thrusters are active only when the reverse discharge is directed over the Lateral Thruster inlet. This means that when one side is pushing water out laterally the other side is not, so you won't have the cancellation in thrust. Additionally there is no need to instruct someone on the operation of the system. There is no way to get it wrong. Very helpful for beginners such as wife, kids and new boat owners. Also Lateral Thrusters work on single engine models as well. This design appears to be for twins only.
I think the system pictured could work for someone very experienced with the system installed but it would take alot of time to get proficient with it. I see a lot of possibilities for counterproductive thrust. Unfortunately during docking maneuvers you must think quickly and execute quickly so a system like this could be stressful to use as well.
Holy crap so let me get this straight F5 plus F3 divided by the square root of thrust vector with a skater thrown in........ oh never mind , I agree this should work !There are some caveats to the picture above of course - it is a ski bucket (not boat), so that is different, the boat pumps generate reverse through the bottom opening (red arrow):
(shown here by my trusted assistant)
So, yes - there is a flaw with the image I posted (I should have indicated more clearly it was a ski pump, not boat). But there is no flaw with the forces.
It is still all Newton Second Law of Motion. Force, mass and acceleration, and vectors of force/thrust.
Lets compare it to the classic example of two ice skaters pushing on a third.
Illustrating this with the head-to-tail force vectors - where forces are vectors and add like other vectors, so the total force on the third skater is in the direction shown:
So - what would it translate (or look like) - at the stern of a twin engine Yamaha jet boat?
Well, lets see!
(this is not a high quality schematic, lol)
F1 through F5 are water jet vectors, so the thrust (force) would have the reverse vector (direction).
The F5 is water bouncing off of the transom, when the nozzles are turned.
(In addition to F5 there would also be water dispersing up and down, I omitted that here for simplicity, but it could further aid the system the same way the factory TDE works. Not the most important here.)
The bottom line - those deflectors can generate lateral thrust to move the stern to a side.
The above example would work with both buckets down at the same time.
So - this would be a "no skill involved" scenario.
With some skill, one could use only one pump/bucket/lateral thruster, so to push the stern to STRBD one would only use the PORT pump - and the F3-F5 would disappear making the system work more efficient/faster.
This might be a good time to bring up the fact i am a Army guy whos been in 18 years but joined with a GED lolThere are some caveats to the picture above of course - it is a ski bucket (not boat), so that is different, the boat pumps generate reverse through the bottom opening (red arrow):
Well, lets see!
