THat's what @COtoFLsurf uses. Very handy.Bet you could stuff a lot of these in there. 50lbs each!
https://wakeballast.com/wakeballast-50-lb-bag-free-shipping-usa-only/
Somehow, I think he gets free shipping... feel for his mailman, lol.
The only thing is - can't dump this ballast when you done.
That could work!What about a helium filled storage container... patent pending!![]()
I'm curious to know why Yamaha only shows and points out what it can do with no ballast. Why not actually show what it can do with the stock ballast setup on one of the wake models.
Sounds good! I hope you make it and test!I came up with an idea for a budget diy booster loosely based on Yamaha's design. 4 inch schedule 40 or 80 pvc pipe long sweep 90 mounted to 1/2 inch thick hdpe plate with recessed stainless bolts. Slight angle cut to both ends of the long sweep 90. Cut the slot for the tie down in the hdpe and secure much the same way. Of course attach a short safety line so if the thing fails under pressure the border will not take it in the face. Testing without a rider first as well. My thinking is this might be a 50-80 percent solution for a small fraction of the cost.
Thoughts? Pitfalls I am missing? Is this entirely stupid?
Ha, yep, here is my previous Centurion at Lake Powell, interestingly enough that is one 1100# sac in the v-drive locker and 500# of lead on the sundeck (plus a couple ballast boys). Water flowed over the back corner so we had to duct-tape the rear vents to keep water out. Crazy wave, but this certainly wouldn't fly down here on the ocean.
Ha, yep, here is my previous Centurion at Lake Powell, interestingly enough that is one 1100# sac in the v-drive locker and 500# of lead on the sundeck (plus a couple ballast boys). Water flowed over the back corner so we had to duct-tape the rear vents to keep water out. Crazy wave, but this certainly wouldn't fly down here on the ocean.View attachment 82146
Completely different story from my dealer. He has 5 on order and said the arrival is 30-60 days. Anyone can buy the package.My local dealer just called and confirmed what we have heard. The Wakebooster can only be ordered with the 2019 watercraft order. It is actually a stand alone line item on the order form like it is a watercraft and not an accessory, thus there is no part number listed yet. It cannot be ordered stand alone, only as a package. And it will not ship until early Feb. 2019. MSRP of $999.
Thank for posting!Not sure if I've missed any but this is the first vid I've seen of the wakebooster on the 212x.
