2kwik4u
- Buffalo, NY
That's about normal for a daily driver with the stock cooler. The stock cooler will likely track engine coolant temps and be offset a bit lower depending on location. Atlanta this time of year those sound like healthy temps.Thank you for the advice.
Yeah, I think you're right... Going for a cooler before the boat arrives. Really like the idea of the new pan.
While working this out and thinking things over, I've been watching the temp to get a base line. Stop-and-Go traffic in and around Atlanta has produced 150F to 175F so far. Not sure if that's normal or not... just what I've seen so far.
Again, just keep it under 220 or so and you should be OK.
