ncnmra
- Ontario, Canada
- X
I think they are separate issues. Nobody is saying that fogging will prevent moisture incursion through engine oil. However, we are suggesting that running the engine briefly WILL. When you fog, you're coating the internals with the oil. Why burn off the fogging oil and introduce engine oil which may have condensation in it by running the engine briefly? Similarly, what is there to gain to run the engine very briefly in the winter? I see @Cobra Jet Steering LLC 's point about cycling the valve springs, but I would surmise that turning the engine over (not actually starting it) would be enough, and better for the engine than starting it for any period less than 10-20 minutes. I would also suggest that repeated cold starts (especially in very cold climates) aren't doing your engines any long term favors (oil viscosity, etc).Ok, so my question still remains what will fogging to do to prevent this?
Of course these are likely minor details and ultimately each one of us needs to do what they feel comfortable with....again; its why I asked because I see a lot of point of debate on every forum regarding these issues...enough to give me a headache.
