Same here basically with some differences:Winterizing in WI for my Yamaha this year:
1) Clean the boat
2) Pull the batteries
3) Add Stabil
4) Store
One of the reasons I went with a boat with jetski engines.
1 - clean the boat
2 - add stabilizer
3 - part i - run the engines for 10 mins+ to distribute the stabilizer in the fuel lines
3 - part ii - start the engines for 15 seconds and blow water out the exhaust
4 - use charger and leave batteries in boat
5 - store
6 - wait for spring...
I like the idea of using Sta-bil and Marvel mystery oil to winterize a boat's engine. I'm not sure about the Sea-foam. Isn't sea-foam used to clean injectors. It might dilute the Marvel Mystery oil. I'm storing my boat in my garage which is heated so thinking I'll just crank the engine ever so often, blow out the water with a compressor, and used the stabil and Marvel. ThanksMany suggest fogging the engine. This is good but not necessary. Mix a "cocktail" of gasoline with 4 gallons of gas, 16 oz. of Sta-bil, 1 quart of Marvel Mystery Oil and 16 oz. of Sea-Foam. Mix in with whatever gas you have in the tank and then get a good enough run in to be sure the mixture is run into the engine. Double the amount of additives if you plan on keeping the tank full (50 gal or so.) throughout the winter Marvel is great stuff and will not hurt the engine or foul the spark plugs. It provides good top end lubrication for the engine to last through the winter. I have owned a carbureted V-6 engine in a Tahoe boat for over 10 years and did this every year with our crap ethanol gas and never had a problem with the carb or starting the following year. I have also used in fuel injected outboards with no issues.
