84rzv500r
- Lower Keys MM29
Just ran over to my buddys house (the one that pulled the LS/AR console hatch molds) and ran YDS on it... it acted funny coming in the other day and he thought it went into Limp mode... a quick scan showed that the issue was low battery voltage that tripped alot of other codes... we had no idea how many hours were on the engine initially YDS shows 6553.5 hours WOW... also the RPM/Hour Histogram doesn't work but everything else did... i think the engine is a 2002... it has a variable displacement scheme where it turns off two or 4 cylinders when not in gear... the only thing I found was #1 spark plug was missing until it got up to temp... I told him to get it warm and then change the plugs and take it out and run it a bit harder or go one hear range warmer with plugs... I cleared all the codes and lets see what happens... He was gonna put in a "new" battery as well the battery was 6 years old... the charging system is working...
