AlpharettaRK
- FSH Sport
I get more water in my bilge than I should. It seems to correlate to running the livewell. I’ve looked at all the hoses, as has my dealer and we see no leaks/loose fittings. We both have looked for other sources of leaks from engine cooling, etc and found none. I don’t have an aerator so I don’t have the unconnected hose issue. Dealer concluded that the standpipe is too tall but Yamaha doesn’t make a shorter one. It is 1-1/4” PVC pipe (not standard thickness) and the threaded fitting on the end is much more coarse than standard PVC pipe.
I left water in the livewell for 5 days between trips and it did not leak, so I think that rules out the base of the standpipe and the cute little blue light. The filler nozzle seems tight. I zip-tied a baggie over the top of the standpipe, made sure livewell was full and after a 15 minute run on choppy lake 2 inches of water was gone. This obviouisly happened without running the livewell pump. This tells me the water is splashing over the top of the livewell (but under the clear lid) as it is a separate piece screwed to the bottom of the deck. Thus if I’m running livewell all day and running around there is plenty of water to splash and fill the bilge. What triggered me is that one day recently I saw the bilge auto-on light twice. To that dealer says “oh well we told you that you need a shorter standpipe”. Seems to me the top of the livewell should be sealed to the deck. There is a crack there and I can’t tell if there is any sealer there but it seems easy enough to go around the top edge inside the livewell with something. Or, little higher degree of difficulty, loosen the screws and if the livewell drops down just a little (which would indicate a complete lack of sealer) shoot sealer in there. Thoughts?
Cheers
Randy
PS - old picture - it's not that clean any more!
Cheers
Randy
