YamFSH210
- FSH Deluxe
Input please from @swatski and @jcyamaharider
I am with you. I have a 2019 FSH 210 can't get a bit over 39 mph. I think I went over 40 once downwind with nearly empty fuel. Now with full crew on board forget about it... runs 34 tops. Thing is a DOG.. Love everything about the boat except top speed. IMO the boat is just underpowered. Gets on plane quickly but no top speed. Damn frustrating to get passed up by everything on the water. fricking DOG! Never thought about the impellers. bought from a dealer in Alabama. I'm in MiamiNo Drag , Even before I installed speed was about the same. Last trip out I looked at them to make sure and at Speed they are riding up out of Thrust.
Hey, wondering if you ever switched out your impellers and what the verdict was. Looking at doing the same if I can improve top speed. ThanksHere is what Glenn at impros had to allow about different impellers , not done either yet but this winter I will order new impellers to help my top speed
I have two choices
Solas YG-DF Dynafly Boat Impeller
14/20 will be to much for the boat, this will need to be pitched to 12/17, this will definitely give you better speed but it might hurt the low end just slightly $281 pitch mod $105
WR007H Driveshaft Holding Tool
9/13 is close to OEM pitch but the difference with this over the OEM is it is machined to locate back in the pump help acceleration. $281 it might bring some speed as well over the OEM.
Boats are the most touchy with the recommendations, a bunch of factors, so when you decide I’m willing repitch at no cost you would just cover the freight.
Thank you
I have switched back to oEM impellers . After installing the impros new pitch , it was way too much . 5000 rpm was all I could get . I did buy a pitch gage and did some small adjustments to the oEM pitch .
No , I picked them based on his two recommendations. I don’t like the idea of having them bent a couple of times and running at high rpm, afraid fatigue would lead to massive issue . I plan on sticking with the oEM and be happy with what it is , love the boat , wish it was faster top end , but it is what it is now . As I have read many posts and there does not seem to be any substantial gains in speed. I’ll sell the impellers cheap if interested . 5 hours maybe on them .
