DiggerPA
- Outside Philadelphia
- Other
Thanks again, that is a great suggestion on adding the RGB speakers. I will look into that. Can you add a single amp to get more power for the speakers without having to add an additional battery, change out the battery switch etc.? Or would the amp run the battery down too quickly? Maybe a smaller amp then what you installed? I know it all depends on how long you would be listening without the engine running. We will mostly be doing water sports more then partying at the sand bar. Sorry for all the questions, I am just not very comfortable playing around with the battery wiring etc.
