So here we go fellas. Here's the update. Got my parts back from a local jet ski mechanic. I dropped the impeller, wear ring, and housing off to him as one piece to get it done for me. Good news its back, but bad news..... Well here goes it.....
Here she is all fixed and ready to go back in. Wear ring had to be dry iced to remove. New wear ring installed same process back in. Impeller was the problem. Solas, revo, and yamaha all back ordered till September at the earliest. So he took mine to a local refinishing shop to have redone. All good, and only cost me $350 out the door.
Got her installed last Sunday with some fresh 5200 and red locktite. Decent looking bead right here on the seal. Wasn't bad too install. Had my son reach down in clean out port and turn shaft while I pushed in. Boom good to go.
Second half all reinstalled and good to go. Everything tightened, and double checked. Moved on to changing my oil and filter. Well.... As per usual with me, and this particular company..... That didn't end well as usual. So here's a pic of something truly not right....
See anything wrong here? Yeah clearly the wrong filter. So back story time..... I ordered a oil change kit from a very popular site used in this forum back in March 2021. Needless to say it never arrived. After many emails asking wtf I finally received my oil change kit mid season. Then 2-3 days later received another just like it. Mind you this site has drop down boxes asking what boat I own. So this is not my mistake here. So being mid season (and under 30 hours) I decided screw it ill wait till next spring to change oil. Fast forward to present day I evacuate all my oil in engine, and super proud moment remove filter without spilling a drop. Come to garage open new box, and WTF oil filter no where near correct. Apparently my 195S is not supercharged, and is a regular 1.8 according to this company. Needless to say..... I don't have anything good to say about them (not the first time I experienced super long ship times), but this just topped the cake for me. My luck honestly. Sooooooooo I flushed old filter with clean oil a couple times and reinstalled. They ain't gonna keep me off the water (still only 35 hours BTW on engine). Filled oil, and let her eat. Screw it... Guess I'll order a correct filter from somewhere that'll get it together
SMH....
There's the hours proof. So brother in law and I took her out for her test spin Monday....
Happy to report she's fixed, but as usual for me.... She ain't 100%. I still have cavitation worse then when I got it 35 hours ago, but not as bad as before impeller fix. However, we could only hit 41mph on the top end whereas before we would hit 48. Not horribly concerned about that because the wife and I normally ride 25-30mph. However, where the Hell did it go. Question..... Could spark plugs be the issue. They are still factory (again 35 hours, and I do not winterize). Might change those out and see, but could also be the impeller resurfacing. Dunno
Bring her home for a full foam cannon spa treatment, plug her in, and cover her up. That's where I'm at boys.
Currently considering:
*Wet Wolf Cone
*5200 seal intake grate
*Wetsounds 8"revo install in rear locations
*Move 6" wetsounds Revos to front locations
*Fatsac for Hopefully more boarding this season
