coryocon
- FSH Sport
Thank you so much for the response and information. I am going to have to run through this list to see where the water is coming from but this gives me a good starting point. I just also didn't think rain water should be getting in there while sitting.Its possible the level wasn’t high enough for the auto to activate. Was the water in the engine compartment above the bilge pump?
If the bilge stopped working automatically, the fuse is blown for the auto circuit, check the individual fuse holders next to the batteries, there are two fuses there associated with the bilge pump, this is in addition to the manually activated circuit with its own ckt breaker on the dash.
Looks like there is power at your dock, do you have an onboard charger? I don’t see a cord from the box going into your boat?
Now lets address why the water is getting into your bilge in the first place, which it should not while sitting out in the rain.
-The first place I’d start would be all of the cup holders, on my 210 FSH none of these were sealed and a lot of water would get in that way when I washed it or when it rained. Also, I found that the cup holders up front drained into the bilge itself, so I put some vacuum plugs on the nipple on the bottom of those cup holders. The two cup holders on the dash may drain onto the deck with the idea that this water will go out through the deck drains in the corners.
-The second place you need to look at is the rod holders, only the very front two, one port and one starboard, had drain lines on them that went overboard. I bought some universal rod holder drains from TH Marine and tied them into the other drains on the boat, so now all rod holders and cup holders drain overboard. Also, pull the rod holders out and seal them to the cap rails / gunnels.
-The third place I’d look be at the deck drains themselves, I have a suspicion this the main source of rain water making it into the bilge. Make sure the deck drain fittings are sealed properly to the deck, pull them out and verify that they are sealed properly. While you are there, make sure the deck drain hoses and such are all clamped properly and are not leaking. You can check this by stuffing a rag in the thru hull fittings and then take a hose and put a couple of inches of water on the deck.
-The fourth place I’d check, and this is probably not where the rain water is coming in but you should seal this up anyway is the clean out tray. From the factory the clean out tray is not sealed very well at all. Just remember to apply the sealant, seal and peel is a good product from DAP or 3M can’t remember which, with the clean out tray installed, you do not want to glue it down. When you pull the clean out tray, make sure all of the clamps in the aft bilge are are tight and in good order. Check for any leakage on any of the thru hulls in this area.
-The fifth place to check is In the engine bay, check to make sure the sea cock line is properly installed and clamped properly.
-The sixth place to check would be the seal around the 5 gallon buck locker in the bow, if necessary tighten the clamping mechanism arm so that when you close the latch it pulls snugly, not tight, on the seal, this lockers should have no water in it even if you rinse the area with a hose.
For sealant I’d suggest either Three Bond Silicone sealer 1211, or 3M 4200. Just be sure you keep the 4200 out of the sun as it will yellow.
I don't have an onboard charger and the dock only has one power outlet to the lift.
I think the water was above the bilge so I may need to check that fuse, but when power was applied dash switch and bilge worked fine.
This is my first time owning a slip/lift and so I am new to this where as I used to only trailer.
