MilesPrower
- FSH Sport
I looked into this a little. It’s the freshwater washdown. Definately not the fuse in the helm locker being the culprit, and I have power at the connector by the pump. So it must be a pump malfunction. When the switch is on, it doesn’t even attempt to run. I despise the thought of trying to get the $&@?er off of where it’s mounted to the fresh holding tank!
Okay... just to be 100% sure... I'll ask a stupid question — apologies in advance:
Do you have a hose connected to the freshwater outlet, and the hose's spray-head open? The freshwater outlet has a valve that automatically closes if there isn't a corresponding quick-release fitting attached to it. Therefore, the pump doesn't run unless you have a hose (or at least the quick-release fitting) attached to the outlet, with the hose sprayer on.
If the circuit breaker isn't popping out, then the pump isn't pulling current while frozen... which usually means the pump's pressure switch is keeping the pump off.
That aside — IMHO, the easiest way to access and unmount the pumps on top of the freshwater tank is to put a couple
Don't bother trying to access the pumps from the starboard hatch next to the engine bay — way too difficult.
