- Tranquility Base
- FSH Sport
Ugh... Just when I thought I finished the project.
I'm starting a radio install next so I'll be running more wires anyways I suppose.
Suggestion, just install a positive and negative bus under the dash. Fuse the positive feed at the battery for the size of feed wire you will use, then use in line fuses or breakers between the bus and devices that will smaller wires.
