ThunderRobo
- 252SE
Alight, before I go down this rabbit hole, I just want to bounce my thoughts off members of JB.
Recently upgraded from a 19’ to a 24.5’, while I’m very happy with the (4pax) 5800rpm/30mph/11.8gph cruise, there’s always a itch for modifications right?
Boat: 252SE
Top Speed 47.6MPH @ 7600rpm
Altitude: 840’msl
Ambient Temps: 60-85f
Since the boat is already able to sit at the factory limiter, I think I’m going to start with the L13 Cones in an effort to increase top-end thrust/speed. If/when I am not able to maintain the 7600rpm at WOT, I’ll then do the panel filter and ribbon delete, and then finally bore out the jet nozzle as needed to get RPMs back into that 7600rpm range.
Just wanted to double check that this is what others would do as well.
Thanks!
Boat: 252SE
Altitude: 840’msl
Thanks!
