255XD Shorelandr trailer advice/questions…
Howdy Pilgrim
255XD
I’m having issues with my Shorelandr trailer that came new with my 2022 255XD.
I already went through 4 brand new tires after one of them became almost completely bald on the outside tread. I hate to say it but I’ve trailered the boat less than 15 times. Maybe 1k-2k miles total
I called my Yamaha shop I purchased the boat from and went through the process of trying to warranty the tires. Took the trailer to an alignment shop, everything checked out perfect and within spec. They gave me all the measurements and good to go.
Noticed after last time to the lake that the boat just continues to feel like I’m dragging it at times. I have attached photos and it appears that the brakes are engaging and potentially staying engaged on the passenger side of trailer (starboard of boat). You can clearly see the wear between the two sides are not equal at all. Img 6671 is port side img 6672 is starboard side and much much more scored and deeper. This is the side where I had issues with the tire as well
Questions/Advice…
1. What could be causing this to happen
2. What are the replacement parts for rotors and pads? Trailer model YAV51TJXWMS0-16
3. Is it normal for them to brake down this quickly or how often do you change your brakes?
Any help is SUPER appreciated as we have a trip coming up that I have to drive 4 hours each way and just want to try and make it safe
Here’s a thread that I did on the trailer bearings and brake maintenance that may help.
Have you been checking the hub temperatures when you tow?
Have you jacked the wheels up and checked for excessive drag?
Typically if a caliper hangs up in its travel the results are dramatic.
I have not checked the hub temps. What would those normally be and how are you recording the temps? I guess I would be looking to see a difference between the too and maybe a temp gun?
I have not jacked up the boat and spun the wheels myself. I was told that was done at the alignment facility because the whole boat/trailer has to be lifted but it would be good to double check myself for sure.
Thank you for the link I will dive in and if the parts are in there I will get those coming asap while I continue to diagnose 😎
You should be able to put your hand on the hubs without getting burned… the brake hubs will always be warmer than the non brake hubs.
Good job on getting the alignment checked.
Did a quick glance through your thread and one thing I didn’t catch was the rotors… are those a standard size or something I can measure and go from there? I apologize for my ignorance didn’t think I’d be messing with these this low of miles lol
