granpachuck
- Cary NC
- 242 Limited S E-Series
Some of the FAQ's found on the 303 site:I used 303 graphene last year, applied in early spring and it kept the boat looking good through the entire season. It wasn't spotless but it looked good enough that I never felt the need to reapply. Will do again in a couple of months.
WHAT SURFACES CAN 303® GRAPHENE NANO SPRAY COATING™ BE APPLIED TO?
303® Graphene Nano Spray Coating™ can be applied to paint, glass, trim, chrome, wheels, and even vinyl wraps. This product is not recommended to be used on tires, although it won’t damage them, it is recommended to wipe up any overspray that occurs on tires.
IS 303® GRAPHENE NANO SPRAY COATING™ MADE WITH PURE GRAPHENE, OR GRAPHENE OXIDE?
303® Graphene Nano Spray Coating™ is made using Graphene Oxide. The hydrogen bonding in the Graphene Oxide allows the material to orientate itself and bond better to exterior surfaces.
DO YOU NEED REMOVE ANY EXISTING COATINGS, WAXES, OR SEALANTS BEFORE APPLYING?
No, this is not necessary. 303® Graphene Nano Spray Coating™ can be safely layered on top of an existing coating and will not negatively affect the coating underneath it, it will only enhance it.
CAN 303® GRAPHENE NANO SPRAY COATING™ BE LAYERED ON TOP OF ITSELF? DOES THIS PROVIDE ANY ADDITIONAL BENEFITS?
Yes, 303® Graphene Nano Spray Coating™ can be layered on top of itself, up to three times. We have found layering up to 3 times yields amazing results. 4 layers or more provides the same value as 3 layers.
DOES 303® GRAPHENE NANO SPRAY COATING™ PROVIDE UV PROTECTION?
Yes, 303® Graphene Nano Spray Coating™ provides UV protection.
IS THERE ANY CURING TIME NEEDED BEFORE THE PRODUCT IS INTRODUCED TO THE ELEMENTS?
No, there is no curing time needed after application.
