RyanF
- North Port FL
- 252S
Hello, I have a 2021 252S and when I’m out on the water all day, the bilge pump kicks on when I run the boat at higher speeds. When I check the clean-out ports, one port is filled with water to the top while the other stays dry. I’ve tightened both hose clamps that secure the rubber sleeve to the fiberglass, but didn’t notice any change. I’m not sure if that’s where the water is getting in or if there’s something else I should be checking.
Thank you for your help
