- Tranquility Base
- FSH Sport
All,
Was chasing mystery water incursion….sometimes no water out the hull drain, other times a couple of gallons. Finally correlated the water in the bilge those times I was taking 5 gallon buckets and washing the deck down.
I found the main deck drain was not sealed well either, removed that cleaned it all up and resealed it. Was still getting water out after the 5 gallon bucket rinse treatment, I started to suspect the 5 gallon bucket storage locker as the source. Found the latch was not pulling the hatch down tight on the seal, tightened the latch bar two rotations and now zero water comes out of the drain plug at the end of the day.
