Can you do us a favor and give us the length of that plastic scupper.....I'm ballparking it at 4 inches???? One I found on Amazon is 5.5"
This is a great call out. It could require some trickery to start the nut on the backside with the scupper partially extended out from the hull then drawn inward in case it's too long to start the nut with the scupper fully inserted. Soap the scupper flange at the stern before installing the deck drain hose.The Attwood 66553-3 is 5.5" overall and 5.25" from the back side of the flange to the end of the 1.5" dia barb. Are there space/placement issues on the 24' boats that require a shorter thru hull fitting?
@jmargo .....me too. ?Crap, And I thought I was safe with scupper being so high.
Take a look at this thread:Now, what about the hole in the anchor locker? Mine only has a plastic bit going thru no valve at all. I need to stick the gopro in there and see how much water can come in at low speeds.Are there any more of these boat sinkers hidden somewhere? View attachment 128852
Place a puppy pad down there before removing the filter. Great tip I learned on here.Cranked it with the plug open. No water. Doesn't seem to be any in the oil, but both are drained. And just to reiterate what has been stated before "what moron engineer madethe oil filter set up?" They obviously never changed oil on anything!
I'll take good measurements tomorrow.HOLD ON TO THAT THING, THAT'S GOLD RIGHT THERE!
Measurements of that are sorely needed. Total length (it's too short, isn't it?), outside diameter, flange width, outside diameter of the through-tube part, and a guesstimate of how short it was (if it's like mine, about half an inch from reaching all the way through, but 3/4" for proper performance.
