Arcadyus
- Washington
- Moomba
- Wake
Does anyone else's engine smoke a little when using the swim deck ballast and wake surfing?
Mine doesn’t smoke but you can see the exhaust as your running higher RPMs at a much slower speed.Does anyone else's engine smoke a little when using the swim deck ballast and wake surfing?
That is nice! WOuld it work up front as well?Oceansouth bimini extension
I took my boat out yesterday without any of the spacers installed and it’s not the Lucky 13 cone. I will be removing the TVW as of right now the boat is just unsafe with it installed. I hope your experience is better than mine was.Were you able to try without the Lucky13 cone? My TVW is being delivered tomorrow and I plan on taking the boat (‘19 AR195) out this weekend.
That's unfortunate. Be curious to see what others find about them.I took my boat out yesterday without any of the spacers installed and it’s not the Lucky 13 cone. I will be removing the TVW as of right now the boat is just unsafe with it installed. I hope your experience is better than mine was.
Me too, I’m very curious to really understand how many people are experiencing the heavy steering issue.That's unfortunate. Be curious to see what others find about them.
I'm sure you could make it work.That is nice! WOuld it work up front as well?
119$ through Amazon.Thinking about doing the same thing. Maybe a DIY setup. Can I asked what they charged?
Thanks for the tip. Just ordered one for my sx 210Oceansouth bimini extension
At 25 it starts moving around.Can you get on plane with it? If yes, how fast can you go? Does it flap around on you?
Oh, that's better than what I thought. Amazon reviews stated much worse than that. Maybe they didn't have it tightned?? Who knows. Thanks for the feedback!At 25 it starts moving around.
On the pump sealant. Where at exactly needs more sealant?Maintenance Items (Grease & Lubricants)
- After combing through a number of different threads I found the following highly recommended products.
Cost
- Pump Sealant = $10.85
- Marine Grease = $11.42
- Clean out plug lubricant = $7.99
Website:
- Pump Sealant: https://www.amazon.com/gp/product/B003B3A9HM/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
- Marine Grease: https://www.amazon.com/gp/product/B004K9FT8K/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
- Clean out plug sealant: https://www.amazon.com/gp/product/B004VTGL9A/ref=ppx_yo_dt_b_asin_image_o03_s00?ie=UTF8&psc=1
Reasoning:
- Pump Sealant: After I installed the Lucky 13 cone I noticed very little to no pump sealant was used which could result in increase cavitation.
- Marine Grease: Grease used on the trailer baring buddies and the impeller baring located in the engine compartment
- Clean out plug sealant: Keep a good seal on the plug and to ensure the rubber does not dry out.
