FSH 210 Sport
- Tranquility Base
- FSH Sport
Not only no load, but hasn’t been charging or discharging for 24 hours.
LOL. I was thinking the same. Just ordered 2 sets! Thanks for the link/info.
Sounds like you have direct experience with the coast guard on this topic, but my reading of the regulation doesn't directly preclude the use of these. So far as I could find, the only direct mention of this is:Again FYI, those spin off knobs are not USCG approved and could be the reason for a failed marine inspection or worse, they are just big wing nuts. I would not use those. There are many boardings in our area, USCG and VSP look at battery connections. Being in compliance and showing it, is a good thing. Mine is a few years old and still helps prevent unnecessary boardings.
But, what’s that? Oh yea, “to each their own”.
Good Morning!
A quick update to my issue. I pulled the batteries yesterday morning. After disconnecting completely, I used my volt meter to test each battery.
House battery=11.2V
Starter battery=12.3V
Needless to say, I am a little confused considering the Connext system literally warned me then shut off in the middle of my boat ride telling me that voltage was too low. I also noticed a small black wire that was connected to the Starter battery that looked pretty worn at the connection. I remember another thread mentioning that this wire needs to make a good connection or there will be issues. Purchased new ring connectors and I will be changing out the worn connector when when I re-install batteries. Hoping the wire has something to do with the issue (ground?)
As far as the batteries themselves, I placed the House battery on charger last night. Checked it this morning and it read 12.3V. Placed the Starter battery on the charger about 30 min ago. Battery was reading 11.2V before connecting the charger.
I am not sure if this opens a whole other can of worms but I appreciate the input.
Thanks, in advance.
If you look at the discharge table that was posted on the first page, you'll see that the house battery is fully discharged when your no-load voltage is 11.2. So it shouldn't be surprising that the system shut off.
You stated in your first paragraph that the starter battery was at 12.3V, but in third paragraph that the starter battery was 11.2V. Not sure what to make of that.
To me anyway, all of this still points to you having drained the house battery by running it a couple of outings in a row without fully charging it in between and having possibly discharged it to the point that it's damaged.
Were it me, I'd replace the house battery again, but in the future, making sure that you fully charge it between outings. A 30 minute run on the water isn't enough to recharge it if you've drained it.
My apologies. That was a typo. I guess I am still asleep! Starter battery was reading 12.3V prior to charging (not 11.2. My mix up).
I agree with charging between outings, the only issue is that boat is kept in a high and dry with no access to power while it is there. I guess I could take batteries home between outings but that will not be fun!
Is the stack indoors or outdoors? Would direct or indirect sunlight on a 100w flexible solar panel with a Victron charge controller work in your scenario while stacked?
No fun indeed.My apologies. That was a typo. I guess I am still asleep! Starter battery was reading 12.3V prior to charging (not 11.2. My mix up).
