Madman
- Sun Prairie, WI
- 252SD
So I’m almost ready to pull the trigger on a new ‘25 252SD.  My current boat came with two group 24 starting batteries, which lasted 13 years and worked just fine for the way we used the boat.  Because the new boat will have digital displays and more electronics, is there a need to upgrade to a larger battery and should I go with a deep cycle for the house?  I’ll have to check with the dealer, but I’m assuming there’s enough room…
		 . But then again, I should probably be happy if I’m around long enough to when I need new batteries!
