Firemedic38
Ok. Quick back story to make sure all is clear. I have an 08 AR230 with a Rule 500gpm Automatic Bilge located between the motors towards the back of the engine compartment. For the record…complete pain in the ass to access the bilge pump. Anyway, realized recently that the pump has been popping the breaker at the helm repeatedly. So I left it off until I got it home. Got the pump off the strainer (still connected to power and discharge hose) and found debris in the strainer. Assumed the issue was that i had a clog which was causing the breaker to trip. Cleaned that all out and the pump ran fine for a long time out of the water.
Today, back on the water. Pump starts tripping again. This continues through multiple power cycling attempts throughout the day. I then simply Turn it off until I get it off the water. Back on the trailer I run the pump and it discharges like normal. WTH!? Either work or don’t work! Don’t fail when i need it and work when I don’t. So now I’m confused and reaching out for help and any ideas you guys may have short of replacing it. That is in the cards and I’ve ordered a replacement but I’d still like to pinpoint the overall problem so I know and am not just replacing things just because.
Thanks!
Thanks!
