Welcome to Jetboaters.net!
ISLAND JAY has your Jetboaters.net Clothing, hats, stickers and more all at a 30% discount until June.
Click Here for more information>SWAG for JetBoaters.net members only
I would worry about heat transfer on the rejex. Applications should be done in the shade below 85 degrees. You truly would waste it as well using a buffer. A orbital maybe.
I bit the bullet and bought some today, lol! I've got a detail closet in my garage that would rival most professional detailers but never owned a boat (this size) before. Although it's in really good condition and has a nice shine just using Hot Sauce, the photo's of everyone's boat with Rejex convinced me to throw some on =)
RejeX was originally developed for the US Air Force to stop turbine exhaust gases from tearing up paint and causing corrosion on alum...
coreex.blogspot.com
excerpt from the link
"Now that you know the background, here is a little product information in case you want to know more. RejeX is not harmful to paint like some products containing silicone oils. Products containing silicone oil (free silicone) will make a car shine really well, but it gets absorbed into paint, which causes very undesirable effects if you need to apply a new coat of paint in the future. Because the free silicone molecules have absorbed deep into the paint, and because they are very slippery, the new paint won’t stick unless the paint shop takes extreme measures to remove every bit of existing paint. Most car owners aren’t aware of the issues surrounding free silicones, but with RejeX you don’t have to worry about this issue at all!"
After my dad passed away, I was going through his car care stuff, and I found and used his NuFinish on my black snow blower. While it was awesome for that, I HATED the application. It may have been old or something, but I would not call it a nice process. It seemed far more difficult than it should to buff out. I saved it to use on the snowmower again, because it WAS better than anything else I'd used. It makes sense that the silicone helped with snow, and when the time comes to repaint it, it'll be taken down to bare metal, so I'm not worried about adhesion.
Actually if you do some research I think will find that waxing the bottom of the boat makes it go slower. I've been told that boat racers typically scuff the bottom of their boats to allow for less friction. I know it sound counterintuitive but if you have a non-waxed surface the water "sticks" to it (think of a waxed car where the water runs off but an unwaxed car the water kinda "sticks to the surface"). So you say, well if water doesn't stick to a waxed bottom, it will be slicker right? Well the kicker is that there is less friction with water on water and more friction with water on gel coat. So you actually want some water to be "sticking" to the bottom of the boat to allow for less friction with the running water. At least this is how I remember it explained to me way back when. Could this all be full of shit? Absolutely, my wife thinks that about stuff I tell her all the time. But its what I remember from somewhere in my past - do your own research, if nothing else its an interesting concept to look into.
Edit: Obviously this affect either way would likely be negligible except in racing where every millisecond counts.
That is correct. The ultimate there are stepped hulls (with a chine across).
In case of our jet boats the caveat here is that any disturbance in surface tension that would promote hull speed moving through the water will also disturb water flow into the intakes, and in case of a stepped hull - air intrusion (ventilation) of the pumps - not good!
I'm about to join the Rejex users and give this stuff a shot.
For those that have used Rejex, what do you use it on besides the gel coat? The black plastic? Powder coated tower? Chrome? Glass?
Also, how bad is it to get it on the vinyl seats - meaning how careful do I have to be when doing the gel coat along the seat backs etc.
