Ozzyj93
 - Miami, FL
 - FSH Sport
Hi everyone. Thanks again for all the feedback. It is very much appreciated. I’ve been doing a lot of research on basically everything. I have a few questions about the maintenance of the boat itself, in terms of cleaning it. I’ll be using it in salt water so based on my research here’s what my cleaning will consist of (P.S. feel free to call me out if it’s overkill. I’m really not sure. I can be very meticulous about cleaning and maintaining expensive items):
-SaltAway: I will use to flush regularly when I am done for the day. Can I use SaltAway mixed with soap to wash the hull and inside?
-CorrosionX: will use to spray the engine every few months. May use on battery cables as well
-Dek Magic: will use for the seadek/mat
-303 cleaner/UV protectant: I will use this on all the vinyl/upholstery
-Regular soap for hull and inside (mixed with SaltAway?): I plan to buy regular soap. Maybe buy a big one at Costco to use one I pressure wash with fresh water
If there’s anything else I should keep in mind or use to maintain all the cables and electronics in the helm, please let me know ? I think someone mentioned to spray silicone inside the helm on the electronics. And then wax for the cables by the bottom of the stern.
Also, with corrosion X there as a protectant, how often should I wash down the engine? If at all? I read somewhere I can just scrub it?
Thanks again all!
Thanks again all!
