Beachbummer
- Houston TX
- SX
If the brand new/rebuilt plugs are not fitting all the way down with a gentle push, and the locking mechanism works well on the plug, the problem is then very likely on the tube itself. I would suggest steel wool to clean the tube very well including the edge at the bottom and the little dimples where the dogs catch into.
The plug should fall into place almost all the way in, flush with the notch on the rear.
