Connext Screen for 2018 210 FSH SPT
Legionnaire
Tampa, Florida
Purchased 2018 FSH SPT that is in great condition minus the Connext screen which had begun to delaminate allowing moisture to enter the device causing corrosion leading to failure. Ordered screen from Partzilla (F4A-U8K12-00-00 DISPLAY UNIT (Yamaha) )in Feb and still waiting to receive. Email response each week is that OEM has modified shipment date meaning whomever they receive the parts from (assume Yamaha) doesn't have the parts to provide. Any help in locating a parts dealer or dealership that has the part available would be greatly appreciated. I am able to operate without it although take special attention to watch pilot tubes and other systems. Glad analog tachs have idiot lights for overheating!
Thanks in advance for your assistance
Mark
Frank Marshall
Nevada City, CA
I've had the same part on order since May 30, 2022. Same issue with delivery and delamination. Ordered from Yamaha Sports Plaza.
Legionnaire
Tampa, Florida
Frank, Have you received the connext screen or are you still waiting? A year would be inexcusable by Yamaha
Legionnaire
Tampa, Florida
Just received update from Partzilla that earliest I will receive a new Connext screen is End of September. Need some help on finding a screen. Concerned I will get stranded at some point. Find this completely ridiculous. HELP
Tranquility Base
Sorry to hear about your screen…. I’ve had really good luck with Vallely Sport and Marine in Bismarck North Dakota. If they do not have the part they can probably give you the straight dope on when the units are expected to be in stock. I’ve mainly dealt with Dan in parts.
701-258-9223
Tranquility Base
Thank you for the info. Will be calling today!
You are welcome! At the very least hopefully you can get accurate information.
I don’t like any of those parts houses, E.G. Partszilla, I truly believe all of them are the same company, in fact when I called two different ones in the past the same guy answered the phone, and upon closer inspection their web sites are the same except for the background colors. Then I figured out they were just using my money as operating capital when they knew they didn’t have the parts, and also knew the parts weren’t going to be available.
The other store I’ve had good luck with is Babbitts on line, but I like Vallely Sport and Marine the best.
Frank Marshall
Nevada City, CA
I called Yamaha trying to get some help. They told me they expected a shipment of screens to arrive early July, but not written in stone. Let's cross our fingers. They also asked for my 8-10 digit Yamaha order number to assure I was in the que.
Tranquility Base
Well that’s not far off! Hopefully that comes to pass and you get your connext screens.
Legionnaire
Tampa, Florida
Frank, Can you pass me the contact info for Yamaha that assisted you, I’m having no luck getting through.
Thanks
Legionnaire
Tampa, Florida
Amazingly enough, I found a Florida Yamaha Dealer that had a Connext screen in stock (1). The only one available in the state of Florida according to my local shop search. I am amazed at the lack of parts for these boats as much as I love it. Looking forward to putting it in next weekend.
Anyone have the "Boatmodel" number that needs to be entered to set up the screen correctly for the 210 FSH SPT
Tranquility Base
Excellent! That model number should be in your owners manual? Did you ever call Vallely?
Legionnaire
Tampa, Florida
Didnt need to as I drove a mile to a boat dealer that sales Yamaha Outboards, asked if they could see inventory and he kindly called the dealer that had the part and I was off to the races. Separately, I have the model number but not sure if that is the same as the number needed for the set up. I will surely try next weekend when I am able to install. Appreciate you
Tranquility Base
That’s awesome man! Good luck with the replacement! Please let us know how it all works out!
That dope you got from the Yamaha outboard dealer is what I was hoping that Vallely would do for you.
Legionnaire
Tampa, Florida
Will record all steps taken and ensure they are posted for others. Thanks again or getting me off my dead a$$ and reaching out to other dealers!!
How much is a new screen from a dealer. Which one is it? 7”?
Legionnaire
Tampa, Florida
Its is the 4.7 inch for the FSH models and the cost was $800
Tranquility Base
Legionnaire
Tampa, Florida
I received the new Connext screen for my 2018 210 FSH SPT and hoped that it would be plug and play. Guess what? It was!!! Ensured batteries were disconnected, pulled the dead one out of the dash. Inserted new one, connected molex connector. I then prayed that I hadn't wasted 800 bucks. Applied battery power to the system, turned on the start battery with kill switch in place and keys in ignition turned one click without starting to give power to the screen. Screen booted perfectly, shod fuel and voltage and I was able to enter diagnostic mode hoping that I didn't have to put in a boat model number that of course I dont have as it is close hold data by Yamaha to ensure they get a few hundred more out of the service call.
System didnt capture original hours which I was afraid of based on other posts. I hooked up my hoses, started the motors applied water and away we went. Immediately buzzer and warning light at bottom right of screen lit up. When I pressed the warning icon, it stated I was over my service interval of 200 hours (which meant if captured my original hours once the motors were started. I went into the motor wellness info and reset the service period (similar to resetting oil change light in your car). Reset both motors, alarms went of and the system is running perfectly and showing original hours. Intend to take it out on Saturday to test the fuel, trip and speed information.
I intend to keep the one I have on order from Partzilla with anticipated date of arrival sometime in September. I am sure there will be someone that needs one and wont be able to get one for a very long time. Thanks to all who provided input to the blog.
Tranquility Base
That’s totally awesome!!!!!!
congrats and thank you for the follow up.
