Connext Screen for 2018 210 FSH SPT
Anyone have an update on these? Mine is out and cannot find replacement. Yamaha said they're on backorder with no date of manufacture or shipping.
In my communication with Yamaha Customer Service, they told me that they have been in dispute with the display manufacture. They have developed a trouble shooting committee to try and resolve. I sent them an email suggesting that if they built a gateway for Yamaha boats to interpret their proprietary NMEA coding, we could at least send the info to our chartplotters to display. So far no word back from them. Sent the email mid March.
I am looking into this links fix: djdynex nmea 2k upgrade It seems doable, but we will have to change the pin numbers to match our boat.
This is extremely disappointing to me towards Yamaha. Looks like this is much more of an ongoing issue than a supply issue. A customer should never have to go to those lengths on his own to correct a parts issue. Looks like I may be trying that route though if something isn't resolved quickly. Thank you for the update though Frank, it's greatly appreciated.
For my 1018 210 FSH, I believe the pins are as follows (although I have not confirmed):
Oil Pressure - ECM Pin 17 Pink/White shorts to ground.
Over temp - ECM Pin 24 Pink shorts to ground.
I believe the AlbaCombi analog to Y2K can hook up to the generators for rpm and hours.
Fuel Level - Fuel electrical connector Pin 1 Pink should give a resistance reading (not sure of high and low yet).
I also plan on tapping house and starter batteries for their voltages.
I believe that Yamaha's NMEA 2k will supply speed thru the water and water temp.
Not sure how to tap engine warning or the Diagnostic Code No.'s Yamaha's connext outputs.
It would be nice if Yamaha developed a gateway, or better yet resolved the delaminating display issues.
Finally got a replacement from Yamaha. 2 1/2 yrs? Ordered May 2022. Unforetunately, the engine hours on the old connext are lost. Yamaha says no way to update. Does anyone have a solution to update the hours?
I replaced my connect screen on my 2018 FSH and the hours populated automatically as the engine ECM‘s appear to have maintained the data. I had no programming requirements whatsoever nor dealer support.
I will connect it take your boat out, run it and see if the engine hours populate should be no issue
Glad to see you FINALLY got the new screen!
Anyone have any new information on these? I see they have them in stock now but $2200? Are the upgraded or different in any way? I don't want to drop 2 grand every few years,
