FSH 210 Sport
- Tranquility Base
- FSH Sport
- 30 gal tank
- Not sure
- mix of 87/93 octane marine fuel
- New plugs /full service in May... only 5 hrs on them. Boat only has 15ish hrs on it
- Salt and brackish
- Impeller/wear ring like new... only 15 hrs - no damage
- Gap is good
- perhaps
Thank you
Right on…
I assume you are mixing the 87/93 to get 91? Very respectfully submitted, according the owners manual your boat, a 1.8L NA engine requires 86 octane fuel. Running higher octane than what is specified will hurt your engine performance, less power and more internal heat. I mix 85 and 91 octane non ethanol fuel to get 86. I use this calculator.
Salt water is more dense than fresh water.. so if you are hunting for that extra few hundred rpms a properly pitched impeller will give you that. I‘m waiting on delivery of my high altitude impellers to get the rpms that I’m missing.
