Fishfinder Install
nvuocolo
Syracuse, NY
Hello All, looking for guidance on how/where to install the transducer on my 2023 AR 250. I have not yet picked out the unit itself but I am fairly certain I will be going with the Garmin ECHOMAP IHD 74cv. Additionally, this is my first boat, I've waited my entire life to buy it so I am certainly a newb and am obviously hesitant to drill any hole into the boat. Any help would be greatly appreciated. I am taking delivery of the boat this Friday. Thank you.
Tranquility Base
Why not have the dealer install it for you? They are familiar with the brand and how the hulls are made.
I was like you, never had a boat before and wanted my boat to be all done when I got it and I had no idea how to do things when I bought it.
nvuocolo
Syracuse, NY
I asked the dealer to do so but the fact is he is just so busy right now that it would push my delivery date even further than it already has which has been over two weeks. I have done some homework and it seems doable but that's why I am deferring to the people here with the knowledge to direct me on how to navigate this.
Steve73
Downingtown, PA
Check out this thread. You want to mount it at the lowest point, you can see in the youtube video how these boats run on plane. I took mine to a Yamaha dealer thinking they would know where to place it and they did not. They placed it way too high, it doesn't ready depth on plane and now I need to get it redone. If you take it somewhere, I would ask them where they are going to put it and make sure the location works.
A lot of guys are using the transom saver attachment (also mentioned in the link above). If you want to try to do it yourself.
RelentlessWMD
Augusta GA - Savannah River
242 Limited E-Series
I have gotten where i trust dealers less and less when it comes to doing work on boats. do your research and do it yourself that way you know its done right, especially when you have a community like this to lean on and ask questions.
The transom saver is a great idea and i will be using it on my next install. I have installed transducers on two other boat successfully the traditional way and still thing the transom save is a good idea.
I too also like the garmin echomap units. have nice features, simple user interface. I am leaning towards a Echomap UHD2 53cv for this new boat. Seems to be a good size.
biffdotorg
Pelican Rapids, MN
I just installed a Garmin Echomap 93 on my fishing boat. The directions are very easy to understand. Their recommendations of where to mount it are spot on.
I did take the time to install a transom saver wtih the two screws and 3M 5200. It's a nice clean install, and allows for adjustments without putting additional holes in the hull. Garmin even included some grommets to run the wire through the hull and show you how to seal it. I had a drain hole I could use, but would have had no issues drilling a hole with their directions if I had needed.
Good luck!
