scottmcclurevt
- SX
I have a 2024 Yamaha SX195. I recently pulled my boat for winterization -- ran great all year with zero issues.
To start winterizing, I ran hose to the system (turning on the water only after starting the engine) to warm up the oil (I shut off the water to the engine before turning it off). When I then changed the oil, I found I had water in the oil. I suspect I may have had my hose pressure too high and somehow contaminated my oil. I completed that oil change. To be safe, I decided to change the oil again just to ensure there was no water left in the system. I did the same as above, and this oil change also showed water in it (albeit maybe not as bad).
If I did get water in the system, how many oil changes would I need to do before really having it cleared out? Any other potential causes I should consider or things I should do to make sure I remedy this correctly?
