Welcome to Jetboaters.net!
Well you couldn't move the top bucket by hand anyhow. Something is binding the linkeage up there on top I bet. or something is stuck in the bucket somewhere
I can pull the bucket into reverse. It’s a 212x so two motors. I’m probably 5 miles to the boat ramp. If I have both motors cranked do I still need to go idle speed to limp in?
Were you using reverse before this happened/ usually things float into the pump recess and lock up the reverse buckets you can actually release the clip where the cable attaches to the bucket and free that then work the bucket loose but be sure to return the cable the same way it came off.
Boat US is great to have in a situation like this, if you couldn't free up the bucket. for a couple hundred bucks a year they would of towed you and the family to safety if needed.
Towing on the water,
Jump Starts,
Fuel Delivery
Soft Ungroundings
Somehow the rod that’s connected to the bucket got bent. I was able to bend it back enough to engage the throttle. I’ll either order a new one or try and fix it tomorrow
