ReelFishingSWFL
- FSH Sport
506 hours over 10 seasons before one suffered a timing chain break leading to both engines being replaced. Now the remaining oem engine is a spare sitting in my garage. Both my Waverunners have the latest version of the 1.8 engine.
If you know / suspect your timing chain going to break I recommend that you replace it immediately. The quote to fix the engine with the broken timing chain was around $2,500, $5,000 to replace all the pistons (to do a complete top end rebuild as well). You can save some money by stripping the engine down before taking it to the shop. $170 per hour is the shop rate here in NCal, at least it was about a year ago.mine keeps jumping timing at 750hr getting ready to replace chain and tensioner. Thankfully nothing crazy just jumps 1 tooth or so and we have to keep putting it in timing over and over. No bent valves got lucky I guess.
Use mine for fishing charter I have a 2017 FSH 190 749hrs and kicking!
Now you know why it idled so rough.Wellllllll I spoke to soon she died at 753 hourswhite smoke burning oil piston rings are far gone 90psi per cylinder she gave out 2 days ago.
