House/start battery issue
Doug Kline
212X
Used the search button but couldn't find any issues similar to mine. 2017 212X
Start battery seems to be draining on the water when in float mode. If I turn just the house battery on and turn on the blower you could see the start battery as well as the house battery drop voltage. Anyone have diagrams of how these batteries should be wired?
How do you know the start battery is draining?
Also, if you turn the start battery switch off, what happens?
I can watch the volts drop on the connext screen. There are two volts gauges, SYS and AUX. i'm assuming the SYS is start an AUX is house. Both of them drop as the blower runs. The start battery switch is off, just the house battery on when this happens.
Mine does the same. I'm sure I've read somewhere in this forum that the voltages on the Connext screen for 2017 (and possibly other years) are not correct.
Best way to see what's really happening is to check the voltages with a DMM. Unless there's a problem with your battery switches, the start battery cannot be discharging if the switch is off.
If I'm in float mode for a while, I just turn the start battery switch off. Never had a problem and I stilll have the original batteries. Probably starting to push things though...
What you could easily do is drop one of these in as a replacement to your current cig lighter adapter (assuming you don't use it) and it'll give you a better indication of voltage
I use one of those and it matches the on board data built into my gages It shows 14.2v on cig adapter and 14.2 on the Yamaha gauge and it drops to 13.6V when I turn on the blower both of these are engine running. The blower draws some voltage/amps for sure.
I really like the Renogy the batt percent amps/to full is sweet.
Dave, you were absolutely correct. With a voltmeter on the start battery, it is rock solid at 13 with the blower on. Although the system volt gauge on the connext screen shows 12.3 and then steady drop. Obviously the voltage gauges on the screens are junk. Don't want to junk up the factory look of the dash so I'll probably put an auxiliary volt gauge in the cabinet under the captains console for the start battery. That way I can glance at it every once in a while we're in float mode just to make sure we're good. Thanks again for your help, it's not the first time that you've given me good advice on this form. Much appreciated.
What are your typical start and house battery voltages when first turning on the ignition and during typical operation, RPMs?
Before cranking the engines you should have 12.8-9 or 13v if your batteries are "full".
After the engine is running you should see 14v which indicates the stator is charging the batteries.
You can also use a Victron Smart shunt with Bluetooth that will work with your phone to check voltages and tell you how much power you have drawn from the house battery.. one shunt wired to the house battery will tell you consumption in Ah and KWh, state of charge, instantaneous amperage flow out of or into the house battery and there is an aux tap that can go to the start battery for voltage and you don’t have to have anything on the dash. I have two of these on my boat, one for the trolling motor bank and one for the house bank. They work great.
Just got one for Christmas. Got the wires. Just need to go install it... Can't wait.
