NGranneman
- SX
Was boating with my 2014 yamaha 210sx this weekend and all of a sudden my left engine would sound off if i attempted to go over 4-5000 rpm. I kept it at 3-4000 rpm to get back to my lift around 2 miles away and engines sounded normal during this part. Tried to rev it up a couple times and do reverse to clear suspected debris but didn’t do anything. Once i got it on my lift I pulled a 2-3 mm rock type substance that seemed wedged between impeller and side along with small 1 inch stick that didn’t really feel stuck. Took it back out and seems to be working fine now. Couple questions as this first time this has happened to me
1) Sound like from debris above or something else I should look into?
2) Why if it is debris seems to do fine below certain rpm?
3) Any damage should be concerned about from driving back at the lower rpm or trying to rev it out a couple times?
