Midnight2V
- Houston Area
@Squirrel, I'll do that as soon as I get back home in June. I should have done a better job of documenting my work, but I completely forgot to do it.
As far as exhaust, I'm not sure what we can do. I believe that the Riva Water box is a direct fit and supposedly adds 15hp on an already modified engine. There is a free flow exhaust available for skis, I'm not sure of fitment, but I'm sure something could be made to work. Here are both links at Riva to give you an idea, but I'm sure other vendors have similar items. I have no idea what gains they might provide though for our boats.
Riva Water box: https://rivaracing.com/i-17283644
Riva Free Flow Exhaust: https://rivaracing.com/i-17283621
It might even be easier to have an exhaust shop weld up a custom pipe. The exhaust is simply removing the sound suppression material, so I don't know if you want to do that given how loud our boats are to begin with. Another thing that might be possible is simply taking the exhaust pipe out and seeing if you can remove (knock out) the sound suppression material. I may have known some people to do this with catalytic converter elements that got clogged from "accidentally" running leaded fuel in unleaded exhaust systems.
One thing I can tell you, having built many supercharged engine combinations over the years, is that a supercharged engine is going to be far more sensitive to intake restrictions than to exhaust restrictions from a pure power making perspective. The two most beneficial exhaust items would be a long tube header and a performance exhaust cam profile.
A long tube header would be problematic for O2 sensor feedback, if you could even find or build one that could fit. It would probably require a custom dyno-based tune to correct readings because of heat losses before the collector cone and O2 sensor bung. Exhaust cams are available, but installation and tuning costs alone (never mind the relatively small cost of the camshaft itself) would make them not worth it for most of us.
