Trevor Shipman
- Charlotte, NC
Will I love you but this is brutal
Also, do you have any video or pics of the wake/wave difference with these installed?
Awesome... but what does the wake look like....
At this point I don't have this data but if you want highest top speed you should select the 1st setting (least deflection angle).What impact does this have on top speed if any based on the three positions and have you identified any speed restrictions based on each of the selected positions?
@JetBoatPilot so if I'm understanding this correctly from the video
Position 1: wakesurf
Position 2: wakeboard (per video "... to tune your wake for wakeboarding simply squeeze, select the second detent...")
Position 3: tubing
This means there isn't an "off" position, the default top position is the "surf" position. Did I understand that correctly?
Thanks. So it will be interesting to see what the result are on the top speed since it seems you are doing a good amount of thrust redirection by default. But I love the ease of use and both sides at the same time is pretty sweet! Can't wait to see the in-use videos and some of the other stats. Congrats on the new product and for your company's continued innovation.Yes surf position is also standard Thrust Vector setting.
I could not agree more as this product will solve several common annoyances caused by the jet wash. I look forward to seeing the video and testing it out on my own!Thanks. So it will be interesting to see what the result are on the top speed since it seems you are doing a good amount of thrust redirection by default. But I love the ease of use and both sides at the same time is pretty sweet! Can't wait to see the in-use videos and some of the other stats. Congrats on the new product and for your companies continued innovation.
Will will I need ballast to surf?????
By the way thank you for awarding us with early adopter pricing!
