J-RAD
- Orem Utah
Hi folks,
I just made it out for the second time this season and noticed a change in my boats performance.
Here's the deal. Beginning 3rd season with the boat, so I'm pretty familiar with he way the boat and it's capabilities. The boat performs perfectly normal in every aspect except for one thing. I'm missing about 1k RPM on the top end. In fact I never would have noticed an issue if I hadn't gone WOT.
During our first outing a few weeks ago we had some smooth water, so I went WOT for a bit and was a bit disappointed as I only hit 40MPH. Which is a few (maybe 5) MPH down from the my top speed. I didn't read much into it, didn't even check RPM...
Today, I decided to attempt a similar test. We had a few more bodies in the boat, but the best it would do was 36MPH at 6500ish RPM. I'm certain I'm missing a significant amount of RPMs from my typical. I'm running at 4,200 elevation
I did a little trouble shooting, checking the obvious.
What do you think's happening?
- Impellers are pristine and clear of debris
- Hull is clean
- Both throttle cables are properly adjusted and reaching the stops on the APS.
- Changed the oil this spring. 4 quarts came out and 4 went back in each engine. Dipstick shows its st the proper level
- Spark plugs are new with the appropriate NGK plugs. Changed after first seasonal start and oil change...
- No warnings
- No overheating
- Water coming from pee holes
- I was using the Hydrophase Ridesteady in RPm mode while cruising. I had the throttles fully engaged and the system asking for more... I did reinstall the nodes after the RSI radio interference repair.
