Did you have any success replacing the aerator pump? How did you get to it?I am having the same issue and ordered a new aerator pump. any suggestion son how to replace? I am not too handy
Thank you!
I would venture a guess that the best (notice I didn’t say easiest) way to get to it would be to remove the panel on the starboard side of the engine bay. If I remember correctly that is what I thought in the past. As I said in a previous post, the pump itself unscrews from the base.Did you have any success replacing the aerator pump? How did you get to it?
Great idea. My connext is disconnected and being replaced, which might explain why that feature isn't working.That’s great info! Now I know where it is!
On my 2020 210 FSH there are settings for the run and off times for the aerator auto in the connext display, perhaps check there?
