- Florida
- Other
- Other
When my timing chain hatched my ski was in the shop for 2 months before it was finally fixed.
Upon it's return I noticed a bad ringing in the pump when running on the trailer so I knew the liner had swelled up and it was hitting the impeller. So I replaced the pump section with a different type similar to what sea doo has and this has been just great with no noises in the pump and no problems in any way.
It has replaceable liners so you don't need to keep buying the entire housing when a liner goes bad.
In any event I was messing around the shop today and I decided to play with the pump liner section that I had removed and replaced .
Everyone knows that the issue is caused by dissimilar metals corroding between the stainless liner and the aluminum housing. Since there is no place for the expansion to get out , it eventually pushes up on sections of the liner and causes it to contact the impeller, this can even lock up the pump as it started to do to me. So decided to experiment with releasing the pressure and dissolving the aluminum oxide in between the two parts. Well I was throwing it away so no big deal if it gets ruined.
I found the spot quite easily and using a 1/4 inch bit I drilled a hole in the aluminum housing directly behind the problem section of the liner, taking care not to drill into the liner itself.
I then inserted a short piece of plastic tubing in the hole and placed a few drops of muriatic acid in the tube. Outdoors obviously! Then I watched the black gunk bubble out of the tube, when it stopped I cleaned the opening with water and decided to use a small ballpeen hammer on the raised section of the liner.
In retrospect I should have made a thin piece of metal to shield the liner from any small marks caused by the hammer but I was not concerned about that since it was just an experiment.
After working the high spot down where it belonged and sanding the area a bit I honestly believe this would save the piece and allow for any further corrosion to be released via the hole, it would not have any way of building up sufficient pressure to bulge the liner again. In any event if you own a older ski and you have more time than money you could try this remedy and see if it saves you some cash.
