geohil
- Salem, Oregon
- X
I lined up the articulating keel at 90 degrees to the transom then I adjusted the steering cables and tie rods so that the were an equal distance from articulating keel using my large framing square to rear bolt hold method. The fangs would have to be bent or bolt holes elongated to accomplish what you are asking about which I would not want to do and I think would defeat the purpose. It will be at least two weeks and probably more before my boat is back in the water to post opinions but even the I would to be able to discern the difference between adding the mega fangs and the toe adjustment since I did both at the same time.
Thanks Mainah - I'll be interested in hearing your opinion. Very curious if the fangs towed out with the pump will lead to bad manners or greatly reduced top speed.
