Babin Farms
- Lower Alabama
- Boatless
- NA
- Other
- NA
If the output voltage is in the mid-13’s to low 14’s at about 1/2 throttle your charging system is good. I’d check both the output voltage & test the battery to see which one is the issue before replacing anything. If it is the battery is use something similar to thisI will check to see what voltage it’s putting out and maybe think about replacing the charging system before buying a new battery. So should I get a starter battery or a deep cycle ?
Are you just making a short trip to where you anchor or do you cruise around a while? If it’s just a short trip the charging system may not have enough time to recharge the battery and after a few outings the battery just gives up.
