No Bilge, No Blower
bgreener
No bilge, no blower working. All else works fine. 2015 AR240 with fully charged batteries. I can't seem to find a fuse box or loose wiring. I have a wet slip and would like to avoid pulling it for an expensive dealer visit. Any suggestions? Thanks in advance.
Not sure about your model year as far as fuse boxes go, but, on my TR-1 powered 2020 210 FSH the fuse box is strapped to the front of the engine(s). Did you check your manual? Usually the manual will direct you to the fuse box location. Also, on my boat, the blowers are protected by a circuit breakers right next to the blower rocker switch.. and when you say ”bilge” I’m assuming you mean the bilge pump, on my boat as well as others there are two protection devices, on my boat there is a circuit breaker right next to the manual bilge pump rocker switch, and then there is a fuse right next to the batteries for the auto function.
