Absorbent pads are your friend here. And maybe a small storage container for a drip pan.So how does everyone go about changing the oil filter without making a mess? Why in the world they have to mount it horizontal is beyond me.
I know what you mean, mine are inverted. I punch two or three holes in the top of the filter to let it drain while I’m removing the old oil. I still pile a bunch of paper towels around the filter base.So how does everyone go about changing the oil filter without making a mess? Why in the world they have to mount it horizontal is beyond me.
The PigPads worked great, especially with the filter position on the 1.8’s. I would slide a couple of the PigPads under the engine just behind the front engine mount which is just below the filter.Pig Pad or others mention diapers. Not all are horizontally mounted, the TR-1 motors in my boat have the oil filter vertically mounted. I don't know how well the diapers work, as I have access to the Pig Pads from work, but @WiskyDan can show you how well they work to clean out any oil that makes it into your bilge. They really only soak up oil, so throw 2-3 of those under the filter, and wrap one of them around the filter while you're removing.
After seeing and dealing with one of those horizontal filters with Dan, perhaps a Form-A-Funnel underneath directing anything into a container would help. It doesn't seem like there's any 100% foolproof way to avoid it, so plan on something to absorb any spillage ahead of time.
It's likely that if you DO have a lower drain fitting, it won't be easier to access than coming from the top.Can you drain the oil like a car from below of does it have to be sucked out through the dipstick tube?
Any tips for cleaning oil off the floor of the engine compartment that wasn’t caught during change? I just did mine and it leaked more than I remembered.
Why not put a bunch of pig blankets down on the floor?Any tips for cleaning oil off the floor of the engine compartment that wasn’t caught during change? I just did mine and it leaked more than I remembered.
