johnso30
- Limited S
I went to change the oil and spark plugs this weekend... tried to start the starboard engine to warm the oil up, but it wouldn’t fire. Have tried several times since with no success. It turns over fine, but doesn’t start. Each time I try, “Check Engine” pops up in the tach after 3 seconds or so. I checked the code, and it flashes 13 and then “crank level signal error” before the tach shuts off. I looked in the service manual and it says that code 13 is the pickup coil. (I’ll be honest... I have no idea what that does...)
I’ll also note that I’ve been having some intermittent issues since last fall with this engine starting if the battery has been off a charger for more than a week or two, but it’s always been just this engine - port engine always starts right up - so I’ve been thinking that there’s a loose/weak electrical connection somewhere. However, this is the first time that I haven’t been able to get it started after putting a booster on the batteries, and also the first time the Check Engine warning has popped up.
So I’m not all that mechanically inclined... so thinking I probably just need to take it to a dealer. Before I do that, thought that I would ask here if there’s something or things that are simple and straight forward that I should try to look at or do myself?
