The fuel system is not going to vapor lock like carbureted engines go because it’s under pressure. I can see the built up heat being an issue in so far as the MAP and IAT sensors go and it pulling the fuel way back. So running the bilge blowers for a few mins before start up would get some cooler air into the engine bay.. no clue as to why it would just stop being an issue.. doesn’t matter since it has stopped. Recently I was taking the temp of the engine bay, both at best cruise and at WFO. I hung a thermometer very close to the air intake and it read 135* on a day when it was 92* outside, this was after cruising for roughly 15 minutes. At WFO the temp was 125*, which makes sense since there is a lot more air flow at max rpm.
Ever since I have been using the no wake mode at level 3 for 15 seconds after trolling for long periods of time I have not had a single issue of longer cranking to get the engines started. I think
@anmut or
@AZMark has been doing the same thing after surfing and no more hard start issues. Haven’t heard anything from
@MrBubbaGump about his hard start issues in a while.. apparently based on his posts there was an issue with the 21’ FSH and hard starts while sitting and the boat rocking back and forth. I think
@lazergeek had an issue this summer when they were out and had been swimming for a while or perhaps it was at dock and swimming and people were walking across the swim deck rocking the boat.
That’s why I asked
@Woodrow what the situation was about his hard start issue. We will see what he has to say…
