leftcoasterfl
- Bokeelia, Pine Island Florida
- FSH Deluxe
Hi all. We were having a great day, then we hit an area with a lot of grass and algae on the way back / (northbound). I am a total noob when it comes to this boat as it is only the second time I have taken it out since Ive owned it. The first time we dumped in Charlotte Harbor which is a large salt bay and with little grass or algae, we ran it for about 10 miles, and had no water in the bilge or any performance issues at all. I bought the boat from a guy who meticulously maintained it and it really is in fantastic shape.
Today, we dumped in in a town called Matlacha. I probably should havent started there now that I know how much grass, hydrilla and algae there is in the pass. It isnt Lake Seminole bad lol. There isnt a mat of grass or algae on top of the water. It would be comparatively like Raisin Bran in a bowl. The bran is the water and the raisins are the grass and algae clumps. The clumps are about golfball to softball sized ones and the hydrilla ranges in size from 6in to 1.5 foot long. On the way out (southbound), which was a run about 5 miles, the boat performed well. One time I thought I was hitting a current, because I lost about 10MPH of speed at the same RPM, but after a minute or so it went right back to cruising speed.
We ended up near Sanibel Island and had lunch. The trip was great so far. So with only a few hours of sun, we headed back (northbound) - the same way we went to there. We were cruising about 30 mph behind another boat that was about 200 feet ahead of us and then the jet starting to cavitate. We lost a bunch of speed. My first thought was we sucked up something. I pulled the clean out and we sure did suck something up. It was a lot of hydrilla. I pulled out enough to fill a large mixing bowl, and probably even more than that. I started the boat back up and we were off again for about a mile. Then the same thing - cavitation. The motor would only thrust below 4K rpm, revving above that did nothing and there was a lot of foam coming out the rear. We check it again and there wasnt a lot of hydrilla in there. Only about a handful. We started the boat again and the same operation happened. Only 5mph at 3000 rpm. Anything more RPMs didn't do anything but make engine noise with no thrust. I drove at 3k rpm for a mile or so and then got to a deeper area of about 10 ft. (the pass channel is 4-6 feet in most places.) I had my daughter put on the snorkeling gear and she went under there and found just a little bit of algae. Only about 1 cups worth. We started the engine again and it was doing the same thing as before. I decided to do reverse/forward/reverse/forward and it 'caught'...we got back to 25-30MPH and was running great. A mile later the same thing happened. We were only about a mile from the ramp, so we just limped home at 5mph/3k rpm.
We got the boat on the trailer and we pulled it out. I looked at the inlet grate and I pulled out about maybe 4 cups of algae. It wasnt a whole bunch, but about the same size as a tiny hand broom (or about the same amount as 3-4 Cabbage Patch Doll's hair). I forgot to put the bilge pump on at this point, so I turned it on and about 2 gallons of water came out of the bilge. Also, there was water in the engine compartment. I would estimate about 1-2 inches deep. It seems like there was lot of splashing going on in there as there was drops on top of the valve cover. I also noticed when were we crawling at 5mph, that there was every once an awhile a puff of steam coming out of the rear jet nozzle area.
So, does anyone one have any advice or does it sound familiar to you? I have had a couple of wave runners before, a couple of OB boats, and a Speedster, and have had grass in the jet before, but was always able to get it out. Is a ball of algae the size of a baseball if you balled it up, cause enough of a restriction to cause this performance behavior? And lastly, below I just noticed this bearing. It looks like the drive shaft bearing. There was a little grease coming out of it. I have a pic below, but would this have anything to do with the slowness issue or it this a different issue or nothing at all?
Yes - I am a total noob with this boat - LOL. Any help and advice is greatly appreciated. Thank you.
Pic of great coming out of the bearing.
