KXCam22
- Kamloops BC
It has been 90 hours since I modified my pump cones to use an oil bath instead of the AP#0 grease. I got this idea from the PWC crowd. I had planned to change the oil every couple of seasons, but never got to it. Changed the oil yesterday and after 90 hours the 100 cc of oil looked good. There was definitely a bit of water contamination but the oil absorbed it with no issues. I used 80W90 amzoil GL5 gear lube. I planned to use Mercruiser synthetic leg oil but shop wasn't open on Sunday so I used the same Amsoil I used last time. I measured the oil quantity this time and it took 100cc to fill the cone and bearing space about 3/4 full. I am very happy with how it is performing, though with only 100cc of oil a guy should maybe change once a year. It certainly doesn't take long to pull both pumps and change the oil. As a test, I ran a super magnet through the used oil and got ZERO metal. Pulled one cone to inspect and it was super shiny and clean inside. Cam.
