VitaminSea
- Central FL
- 252SD
Those are bent mine are perfectly straight . Use two adjustable wrenches tighten onto the metal and give it some love, bend it back straight. Someone showed me this and have used it to fix plenty of metal pieces that were bent or needed some adjustment.
The ladder just bolts directly to the hull via embedded nuts. There may be washers between the frame and bolts but I don’t think so. Still, I’d put some on blaster or wd40 on them before trying to remove the bolts (it would suck to strip the fiberglass around the embedded nut).@Ronnie - Thanks for reaching out. I was actually thinking of sending you a DM, but you beat me to it. Does the ladder frame just screw into the hull, or does it have washers/nuts on the backside?
BTW, it does appear to be a Windline, appreciate that info!
Hi do you have this available?FYI - if your ladder if made by Windline it comes with a limited lifetime warranty. I’ve replaced two with Windline, one just cost me shipping the other Windline sold me for about half off of retail/yamaha sports plaza’s price.
alternatively, I have one for sale from a 2017 ar 240.
$100 plus actual shipping and packaging costs.
It’s no longer available as I bent mine a year ago so I replaced it with this.Hi do you have this available?
I ended up buying a generic one from Amazon for like 60 bucks. I had to drill new holes in it but otherwise it works fine. I just looked it up but that particular one is no longer available.It’s no longer available as I bent mine a year ago so I replaced it with this.
