Shorelandr Trailer Winch Strap
NoFla21
NE FL
Well, this is a first. Took the boat out with the family and loaded it back on the trailer. Cranked the winch strap till right before the eyelete on the boat hit the roller. Went to tighten it to the roller and POP! Winch strap just shredded and broke apart. Definitely didn’t expect it but at least it happened once I got the boat on the trailer.
Any recommendations on what strap to add? I want something to last forever.IMG_0087.jpeg
Two tips on winch straps. Be sure it is 2", most are, but measure. Also pull the old one out and confirm you know how to pull the pin to remove the old and install the new.
Otherwise, the straps are pretty generic and will sun rot no matter how much you want them to last forever.
Any recommendations on what strap to add? I want something to last forever.View attachment 228014
Suggestion.....Looks like you have some excessive wear on the Gear Side of the strap. Make sure it is winding straight when loading. I have had a strap do the same. Purchased one off Amazon as Kgower listed and it lasted longer than the OEM.
